USG20W-VPN Firmware 5.31(ABAR.0) Wrong CLI Command Delete Old Configuration Backups (4.65 Works)
SierraTech
SierraTech Posts: 50 image  Ally Member
First Comment Friend Collector Seventh Anniversary
Attempting to delete old Firmware Router Backups Configuration Files (i.e. Configurations Based on 4.60 and earlier), the following error messages occurs:
When I switched back to 4.65, I was able to delete 4.35 and earlier with no issues. I will have to switch back (Reboot on Standby Partition 4.65) again to delete these configuration files.
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    It does not solve the problem with 5.31 (WK31 or not?), but worth a try: renaming the backups with short and letters only name (+.conf at the end) make files deletable?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @SierraTech
    Not sure if the name of the config file is too complicated. Could you share the config file and its name to us via private message? Besides, you might rename the config file and delete it, as below:
    STEP1. Rename the config file.
    STEP2. Remove it.
    STEP3. Press "Yes" to remove it.
  • Zyxel_Jeff
    May I know your config file name whether including “()” parentheses? If so, please rename it, and then you can delete this config file. Besides, the file name format cannot be named with “()” parentheses on 5.31 firmware(as the below example) due to avoiding some injection CLIs towards our ZySH daemon and causing some unexpected problems. Sorry for your inconvenience.
