NXC2500 controller does not see dots NWA1123ACv3
Hello. There is an NXC2500 Controller. Bought several NWA1123ACv3 points. Controller and points in one vlan. DHCP points receive from the controller. Option 138 on DHCP is enabled. The point is not visible from the web interface of the controller. What needs to be done so that the controller can see these points?
Hi @RDD123456
Welcome to Zyxel community!
NWA1123ACv3 can be used in standalone and Nebula mode only, not supported controller management such as NXC2500.
If you’d like to centrally manage device, you could consider using Nebula to get real-time network information and gain effortless control.
Thank you
Regards,
Bella
AFAIK, at least LAN1 or LAN2 (as default configuration) connection between AP and the controller must be available to allow detection and configuration.
However: I (personally) do not know if NWA-1123ACv3 is manageable from NXC2500.0 -
Hi @RDD123456
Thank you
Regards,
Bella
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
