NXC2500 controller does not see dots NWA1123ACv3
RDD123456
RDD123456 Posts: 1
First Anniversary
edited May 2024 in Wireless
Hello. There is an NXC2500 Controller. Bought several NWA1123ACv3 points. Controller and points in one vlan. DHCP points receive from the controller. Option 138 on DHCP is enabled. The point is not visible from the web interface of the controller. What needs to be done so that the controller can see these points?
  • Zyxel_Bella
    Zyxel_Bella Posts: 560  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @RDD123456
    Welcome to Zyxel community!
    NWA1123ACv3 can be used in standalone and Nebula mode only, not supported controller management such as NXC2500.
    If you’d like to centrally manage device, you could consider using Nebula to get real-time network information and gain effortless control.
    Thank you
    Regards,
    Bella
  • mMontana
    mMontana Posts: 1,432  Guru Member
    AFAIK, at least LAN1 or LAN2 (as default configuration) connection between AP and the controller must be available to allow detection and configuration.
    However: I (personally) do not know if NWA-1123ACv3 is manageable from NXC2500.
  • Zyxel_Bella
    Hi @RDD123456
    Thank you
    Regards,
    Bella
