No traffic with VPN site-to-site with 2 USG behind router
Good morning,
i have 2 firewalls (USG40 + ATP100) and i created a site to site IPSEC VPN. The vpn connects correctly, but I cannot pass traffic from one side to the other.
Both firewalls are behind routers.
I followed this guide using the steps related to the configuration behind the router: https://support.zyxel.eu/hc/it/articles/360000719120-Come-configurare-VPN-da-sito-a-sito-IPSec-mentre-un -site-is-behind-a-NAT-router
I hope someone can help me, thanks
    PeterUK Posts: 3,960  Guru Member
    Post pic of the config for both ends with advanced view
    Do you see anything blocked in logs
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,338  Zyxel Employee
    Hi @s4it_federico
    Could you share the site-to-site VPN behind NAT topology with IP address to us? as below:
    Site A LAN subnet<=>(LAN)USG40(WAN:private IP) <=>ISP A Router <=Internet=> ISP B Router => (WAN:private IP)ATP100(LAN) <=> Site B LAN subnet
    What are LAN subnet domains(with IP range) cannot transfer traffic between Site A and Site B? What kind of traffics do you transfer(such as FTP)? When the traffic cannot be transferred, are there any security policies or UTM features blocked messages that can be observed on the Monitor Log page?
    Thanks.
  • Site A 192.168.0.0<=>(192.168.0.1)USG40(WAN:192.168.99.2) <=>192.168.99.1 (public 185....) <=Internet=> (public  93....) 192.168.5.1 => (WAN:192.168.99.2)ATP100(192.168.10.1) <=> Site B 192.168.10.0
    VPN Connection ATP100
    VPN Connection USG40
    VPN Gateway ATP100
    VPN Gateway USG40
    edited September 2022
    For the ATP100 thats connected to a router doing NAT have you set DMZ to 192.168.5.2? or try nailed-up on the ATP100 with the USG40 connected router DMZ to 192.168.99.2
    Have you enabled Policy Control for from WAN to zywall UDP 500 and 4500
    Does the status show connected?
    Is Use Policy Route to control dynamic IPSec rules unchecked?
  • mMontana
    mMontana Posts: 1,434  Guru Member
    The "Casa" side has a dynamic IP?
  • Zyxel_Jeff
    Hi @s4it_federico
    You could add policy route and security policy on USG40, ATP100 sites, as below:
    USG40
    (1). To create a policy route (Network > Routing > Policy Route)
    Incoming: Interface
    Member : lan
    Source IP: 192.168.0.0/24
    Destination IP: 192.168.10.0/24(Site ATP100)
    Next-hop: VPN tunnel, select the VPN tunnel to Site ATP100
    (2). To create a Security Policy (Security Policy > Policy Control)
    To: IPSec_VPN
    Action: allow
    ATP100
    Incoming : Interface
    Member : lan
    Source IP: 192.168.10.0/24
    Destination IP: 192.168.0.0/24(Site USG40)
    Next-hop: VPN tunnel, select the VPN tunnel to Site USG40
    To: IPSec_VPN
    Destination IP: 192.168.10.0/24(Site USG40)
    Action: allow
  • valerio_vanni
    valerio_vanni Posts: 157  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Are you sure about the bold part?
    WAN 192.168.99.2 cannot reach its gateway 192.168.5.1, if you don't set a large netmask.
    Another thing: ISP routers are forwarding needed ports to Zyxel devices?
    Sorry, my error the WAN is not (WAN:192.168.99.2)ATP100 but (WAN:192.168.5.2)ATP100
