PPPoE fails after changing from ASDSL to VDSL (incl. modem) with Deitsche Telekom
Our USG40W worked fine until we changed modem from ADSL to VDSL with Zyxel Speedlink 5501 configured as modem. We can't esablish connection - I even see no traffic according to dialout or pppoe negotiating. Where ist the difference to adsl-modem.
Best Answers
Hi Christian,
thanks for your thoughts. Since I just changed from a sinple ADSL modem to Speedlink5501 as VDSL modem with the same ISP and credentials, I don't believe that thas is the reason.
Regards
Hartmut
Did you configured a VLAN tag @ your wanport
check this document
https://www.telekom.de/hilfe/downloads/octopus-f50-bng-adsl.pdf
5
in Germany there are some reseller for DTAG ISP credentials. i had the Feature, the username required a different character, that is for the type of VDSL in the string required to get connected.
in my case i had to add "H" for the 1st character in the username to get connected trough VDSL.
Regards
Christian0 -
Hi Christian,
Regards
Hartmut
check this document
5 -
Thanks, Mark, for your interesting hint. Might solve the problem. I have to leave confirmation to others since I decided to configure the 5501 as router with the USG40 as DMZ. Besides to the as reserved remarked TCP Port I had to omit UDP 10000. All other ports and GRE are passed to the DMZ. Not what I had in mind (another wrangling with the traffic) but it works.0
- 588 USG FLEX H Series
- 477 News and Release
