log messages
I have a Zyxel GS 2210-HP switch and I have Dlink DAP-2610 antennas connected to that switch. A few days ago the antennas are restarting and the following log started to appear on the switch:
6432 Sep 06 15:38:53 NO system: PethPse Port 18 OnOff Trap, Port Detection Status is Disabledabled
6434 Sep 06 15:38:53 NO system: PethPse Port 16 - AP-P16 OnOff Trap, Port Detection Status is Disabled
6435 Sep 06 15:38:53 NO system: PethPse Port 15 - AP-P15 OnOff Trap, Port Detection Status is Disabled
6436 Sep 06 15:38:53 NO system: PethPse Port 14 - AP-P14 OnOff Trap, Port Detection Status is Disabled
6437 Sep 06 15:38:53 NO system: PethPse Port 12 - AP-P12 OnOff Trap, Port Detection Status is Disabled
what does this log mean? What it means?
@Gel,
The log "6432 Sep 06 15:38:53 NO system: PethPse Port 18 OnOff Trap, Port Detection Status is Disabledabled" means when you login to the switch and disable PoE (on port) then this log will show up.
For your other question, since there is no power supply problem or CRC error on each port, everything is fine, the link changed event may trigger by AP itself (ex. upgrade firmware and reboot) please check your AP's log may find further information.0
gentlemen, at other times the ports look like this:
2 Sep 19 14:35:30 DE interface: Port 15 - AP-P15 link up3 Sep 19 14:35:26 DE interface: Port 15 - AP-P15 link down4 Sep 19 14:35:15 DE interface: Port 15 - AP-P15 link up5 Sep 19 14:35:08 DE interface: Port 15 - AP-P15 link down6 Sep 19 14:32:22 DE interface: Port 16 - AP-P16 link up7 Sep 19 14:32:18 DE interface: Port 16 - AP-P16 link down8 Sep 19 14:32:07 DE interface: Port 16 - AP-P16 link up9 Sep 19 14:31:59 DE interface: Port 16 - AP-P16 link down10 Sep 19 14:25:14 IN authentication: HTTP(s) user admin login [IP address = 192.168.10.6]11 Sep 19 14:19:38 IN authentication: HTTP(s) user admin login [IP address = 192.168.10.6]12 Sep 19 14:16:10 DE interface: Port 16 - AP-P16 link up13 Sep 19 14:16:06 DE interface: Port 16 - AP-P16 link down14 Sep 19 14:15:55 DE interface: Port 16 - AP-P16 link up15 Sep 19 14:15:48 DE interface: Port 16 - AP-P16 link down16 Sep 19 14:14:42 IN authentication: HTTP(s) user admin login [IP address = 192.168.10.6]17 Sep 19 14:14:25 DE interface: Port 3 - AP-P03 link up18 Sep 19 14:14:21 DE interface: Port 3 - AP-P03 link down19 Sep 19 14:14:10 DE interface: Port 3 - AP-P03 link up20 Sep 19 14:14:03 DE interface: Port 3 - AP-P03 link down21 Sep 19 14:12:38 DE interface: Port 10 - AP-P10 - ELC link up22 Sep 19 14:12:34 DE interface: Port 10 - AP-P10 - ELC link down23 Sep 19 14:12:23 DE interface: Port 10 - AP-P10 - ELC link up24 Sep 19 14:12:16 DE interface: Port 10 - AP-P10 - ELC link down25 Sep 19 14:10:54 DE interface: Port 11 - AP-P11 link up26 Sep 19 14:10:50 DE interface: Port 11 - AP-P11 link down27 Sep 19 14:10:39 DE interface: Port 11 - AP-P11 link up28 Sep 19 14:10:32 DE interface: Port 11 - AP-P11 link down29 Sep 19 14:07:18 DE interface: Port 3 - AP-P03 link up30 Sep 19 14:07:14 DE interface: Port 3 - AP-P03 link down31 Sep 19 14:07:03 DE interface: Port 3 - AP-P03 link up32 Sep 19 14:06:56 DE interface: Port 3 - AP-P03 link down33 Sep 19 14:06:47 DE interface: Port 7 - AP-P07 link up34 Sep 19 14:06:32 DE interface: Port 7 - AP-P07 link down35 Sep 19 14:06:30 DE interface: Port 7 - AP-P07 link up36 Sep 19 14:06:14 DE interface: Port 7 - AP-P07 link down37 Sep 19 14:06:11 DE interface: Port 11 - AP-P11 link up38 Sep 19 14:06:06 DE interface: Port 11 - AP-P11 link down39 Sep 19 14:05:55 DE interface: Port 11 - AP-P11 link up40 Sep 19 14:05:48 DE interface: Port 11 - AP-P11 link down41 Sep 19 14:05:45 DE interface: Port 5 - AP-P05 link up42 Sep 19 14:05:41 DE interface: Port 5 - AP-P05 link down43 Sep 19 14:05:30 DE interface: Port 5 - AP-P05 link up44 Sep 19 14:05:23 DE interface: Port 5 - AP-P05 link down45 Sep 19 14:03:05 DE interface: Port 15 - AP-P15 link up46 Sep 19 14:03:01 DE interface: Port 15 - AP-P15 link down47 Sep 19 14:02:50 DE interface: Port 15 - AP-P15 link up48 Sep 19 14:02:43 DE interface: Port 15 - AP-P15 link down49 Sep 19 13:56:46 DE interface: Port 15 - AP-P15 link up50 Sep 19 13:56:42 DE interface: Port 15 - AP-P15 link down51 Sep 19 13:56:31 DE interface: Port 15 - AP-P15 link up52 Sep 19 13:56:24 DE interface: Port 15 - AP-P15 link down53 Sep 19 13:51:18 DE interface: Port 7 - AP-P07 link up54 Sep 19 13:51:03 DE interface: Port 7 - AP-P07 link down55 Sep 19 13:51:02 DE interface: Port 7 - AP-P07 link up56 Sep 19 13:50:46 DE interface: Port 7 - AP-P07 link down57 Sep 19 13:50:34 DE interface: Port 15 - AP-P15 link up58 Sep 19 13:50:28 DE interface: Port 15 - AP-P15 link down59 Sep 19 13:50:24 DE interface: Port 16 - AP-P16 link up60 Sep 19 13:50:19 DE interface: Port 16 - AP-P16 link down61 Sep 19 13:50:17 DE interface: Port 15 - AP-P15 link up62 Sep 19 13:50:10 DE interface: Port 15 - AP-P15 link down63 Sep 19 13:50:08 DE interface: Port 16 - AP-P16 link up64 Sep 19 13:50:01 DE interface: Port 16 - AP-P16 link down65 Sep 19 13:41:00 DE interface: Port 4 - AP-P04 link up66 Sep 19 13:40:56 DE interface: Port 4 - AP-P04 link down67 Sep 19 13:40:45 DE interface: Port 4 - AP-P04 link up68 Sep 19 13:40:38 DE interface: Port 4 - AP-P04 link down69 Sep 19 13:38:45 DE interface: Port 5 - AP-P05 link up70 Sep 19 13:38:41 DE interface: Port 5 - AP-P05 link down71 Sep 19 13:38:30 DE interface: Port 5 - AP-P05 link up72 Sep 19 13:38:23 DE interface: Port 5 - AP-P05 link down73 Sep 19 13:31:04 DE interface: Port 1 - AP-P01 link up74 Sep 19 13:31:00 DE interface: Port 1 - AP-P01 link down75 Sep 19 13:30:49 DE interface: Port 1 - AP-P01 link up76 Sep 19 13:30:41 DE interface: Port 1 - AP-P01 link down77 Sep 19 13:30:08 DE interface: Port 10 - AP-P10 - ELC link up78 Sep 19 13:30:03 DE interface: Port 10 - AP-P10 - ELC link down79 Sep 19 13:29:52 DE interface: Port 10 - AP-P10 - ELC link up80 Sep 19 13:29:45 DE interface: Port 10 - AP-P10 - ELC link down81 Sep 19 13:29:43 DE interface: Port 11 - AP-P11 link up82 Sep 19 13:29:37 DE interface: Port 11 - AP-P11 link down83 Sep 19 13:29:26 DE interface: Port 11 - AP-P11 link up84 Sep 19 13:29:21 DE interface: Port 16 - AP-P16 link up85 Sep 19 13:29:17 DE interface: Port 16 - AP-P16 link down86 Sep 19 13:29:12 DE interface: Port 11 - AP-P11 link down87 Sep 19 13:29:06 DE interface: Port 16 - AP-P16 link up88 Sep 19 13:28:59 DE interface: Port 16 - AP-P16 link down89 Sep 19 13:14:02 DE interface: Port 4 - AP-P04 link up90 Sep 19 13:13:58 DE interface: Port 4 - AP-P04 link down91 Sep 19 13:13:47 DE interface: Port 4 - AP-P04 link up92 Sep 19 13:13:40 DE interface: Port 4 - AP-P04 link down93 Sep 19 13:12:46 DE interface: Port 3 - AP-P03 link up94 Sep 19 13:12:42 DE interface: Port 3 - AP-P03 link down95 Sep 19 13:12:31 DE interface: Port 3 - AP-P03 link up96 Sep 19 13:12:24 DE interface: Port 3 - AP-P03 link down
could it be a problem with my zyxel equipment?0 -
@Gel,
May I know if all the AP are powered by PoE? On the other hand, could you please help me to collect tech support file (Please private message me), at Management>Maintenance.0 -
@Gel,
For your other question, since there is no power supply problem or CRC error on each port, everything is fine, the link changed event may trigger by AP itself (ex. upgrade firmware and reboot) please check your AP's log may find further information.0 -
yes, all Aps are powered by POE
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
