Android 12 and ikev2
13
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,321
    Hi @DavideV,
    This issue is fixed in V5.31 firmware. Please update to V5.31 and try it again.
    V5.31 release note:
     9. [ENHANCEMENT] eITS#180900304, 180801037
         a.Support VPN multiple Diffie Hellman groups.
  • mMontana
    mMontana Posts: 1,249
    50 Answers 1000 Comments Friend Collector Fourth Anniversary
  • Zyxel_Cooldia
    Hi @mMontana,
    The issue is fixed in WK35.  Lab test on Google Pixel 5 Android 13, and Xiaomi poco F3 Android 12.
    Both mobile phone can build up IKEv2 + PSK tunnel successfully. We may need to check if the issue is something related to specific brand mobile phone.
  • mMontana
    Thanks for your kind reply. :)
  • Zyxel_Cooldia
    Just found out that, if we test on Samsung mobile phone IKEv2 + PSK Remote access VPN, we cannot just provide 1 DNS server in phase 2 mode config. Mobile will send "DEL" message to gateway immediately when the tunnel is up assume we just set up 1 DNS server for mode config.
    That's weird. other brand mobile can accept one DNS server in mode config.
    Not sure if it is limitation on specific version.
    Condition :
    Samsung Android 12 + IKEv2 + PSK
    Mode config: Need to set up 2 DNS server for Samsung mobile in phase 2 mode config
  • mMontana
    Hint for @Zyxel_Cooldia: update the manuals and the howtos published.
  • Peppino
    Peppino Posts: 104
    edited December 2022
    Dear Zyxel team,
    Now that Android 13 has rolled out onto Samsung phones, and L2TP has practically stopped working on them, I was wondering if you guys have a plan to overcome this situation, as Samsung apparently still uses a weird hashing algorithm, that we cannot set in the Zyxel firewalls if trying to move towards IKEv2.
    Whatever I tried wouldn't let me past Phase 1.
    This guide here unfortunately doesn't work for these phones, you may consider putting there a note, that Samsung phones are an exception.
    Any chance we can get back our VPNs soon? :-)
  • Zyxel_Cooldia
    Hi @Peppino,
    We would suggest to install Strongswan client on Samsung phone for IKEv2 connection.
  • Peppino
    Peppino Posts: 104
    Hi @Peppino,
    Can you eventually suggest a configuration guide for this?
  • Peppino
    Peppino Posts: 104
    I actually succeeded setting it up, but it might not be trivial for others
Security Highlight
