Zyxel security advisory for insufficient entropy vulnerability of GS1900 series switches
CVE: CVE-2022-34746
Summary
Zyxel has released patches for GS1900 series switches affected by an insufficient entropy vulnerability. Users are advised to install them for optimal protection.
What is the vulnerability?
An insufficient entropy vulnerability caused by the improper use of randomness sources with low entropy for RSA key pair generation was found in Zyxel GS1900 series switches. This vulnerability could allow an attacker to retrieve a private key by factoring the RSA modulus N in the certificate of the web administration interface. In addition, the attacker could use the private key to decrypt TLS-secured connections or impersonate the certificate owner.
What versions are vulnerable-and what should you do?
After a thorough investigation, we have identified the vulnerable products that are within their vulnerability support period, with their firmware patches shown in the table below.
Affected model |
Affected version |
Patch availability |
GS1900-8 |
V2.60(AAHH.4)C0 |
GS1900-8HP |
V2.60(AAHI.4)C0 |
GS1900-10HP |
V2.60(AAZI.4)C0 |
GS1900-16 |
V2.60(AAHJ.4)C0 |
GS1900-24 |
V2.60(AAHL.4)C0 |
GS1900-24E |
V2.60(AAHK.4)C0 |
GS1900-24EP |
V2.60(ABTO.4)C0 |
GS1900-24HPv2 |
V2.60(ABTP.4)C0 |
GS1900-48 |
V2.60(AAHN.4)C0 |
GS1900-48HPv2 |
V2.60(ABTQ.4)C0 |
Got a question?
Please contact your local service rep or visit Zyxel’s Community for further information or assistance.
Acknowledgment
Thanks to the following researchers for reporting the issue to us:
- Chris Papathanasiou and Kyprianos Vasilopoulos from Panthera Labs
- Maximilian Radoy, Sven Hebrok, Robert Merget, and Juraj Somorovsky from Paderborn University
- CERT-Bund, the Computer Emergency Response Team for Germany's federal authorities
Revision history
2022-09-20: Initial release.
Seems that link for V2.70(AAHI.3)C0 for GS-1900-8HP doesn't work.
Edit: same version seem released 9th august 2022. This latter is already containing the patch for the vulnerability disclosed?1 -
There is an erroneous %10 on the end of the link, following the .zipmMontana said:Seems that link for V2.70(AAHI.3)C0 for GS-1900-8HP doesn't work.
Edit: same version seem released 9th august 2022. This latter is already containing the patch for the vulnerability disclosed?0
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
