USG60W - WIFI PROBLEM
After upgrading to v4.32 it seems that there is a WiFi problem. I have the same case on two USG60W that we use only the built-in antennas. In both cases WIFI works for some days and suddenly it disconnects all the devices and don't accept any new connections claiming that there is an error with the key. After rebooting USG everything is ok.
Generally speaking I would find very helpful if there was a way to reboot only the wi-fi service instead of the whole USG.0
I have had the same issue on my USG60W on 4.32
Hi @DadB
I will send you the firmware by private message. Please has a check.
Hi Stanley, can you also send me?Zyxel_Stanley said:Hi @DadB
@sk8erbender
wil pm you0 -
Hi, i need new firmware also.. Can u send it..?0
It seems that this error has become very popular. Has Zyxel detect the cause of this error? When shall we wait for a hotfix on this?
Brand new, firmware updated USG60W with the same problem.
- 588 USG FLEX H Series
- 477 News and Release
