Flex 200 Dual WAN Configuration
tmiller
tmiller Posts: 4 image  Freshman Member
Hello All,
I have a fleet of USG Flex 200 routers deployed.  WAN 1 is static IP from ISP, WAN 2 is private IP (no internet access) from cellular modem.
Goal here is traffic from LAN is IPSEC through WAN 1 when possible to private network.  If WAN 1 were to ever fail, Zyxel should fail over to WAN 2 and my LAN address should still be able to communicate to my private network, as WAN 2 would be in this private network as well.
I have a problem though, where sometimes the USG FLEX 200 will failover to WAN 2, but then not switch back to WAN 1 when it is available.  It's keepalive address is 8.8.8.8, which is confirmed up at the time it is communicating through WAN 2.  If I physically unplug WAN 2 from the Zyxel, it fails over fine.
I have my Trunk configured to be WAN 1 active, WAN 2 passive.  I've dropped thoroughput to 1 kbps up/down on load balancer.  Still Flex 200 seems to get stuck on WAN 2 for some reason?
This problem has persisted on every firmware I've tried, including newest one.
Any suggestions?
    PeterUK Posts: 4,429 image  Guru Member
    Have you made a routing rule to WAN1 with Connectivity Check to 8.8.8.8? seem you have the check on the interface.
  • tmiller
    I just have it on the interface.
    I have never tested fail over with a Trunk setup I do it by routing rule.
    Incoming interface
    member LAN1
    next hop
    type interface
    interface WAN1
    advance
    check
    Disable policy route automatically while Interface link down
    Enable Connectivity Check
    ping setup you set to 8.8.8.8
  • tmiller
    With LAN1 next hop WAN1, that won't stop LAN1 traffic from going out IPSEC when WAN1 is active, would it?  I'll have to setup a bench test, but I appreciate the assistance!
    edited September 2022
    The IPSEC will go out WAN1 by the Trunk setup you can if needed make routing rule:
    Incoming ZYWALL
    service IPSEC group with port 500, 4500, 1701 and Protocol=50
    next hop
    type interface
    interface WAN1
    Thinking about it if the IPSEC is set on a given interface then it will use that interface
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @tmiller
    I test the trunk in my LAB also have connectivity Check on the interface,  The outbound traffic will switch back  to the "active" one when WAN1 go online .
    Shared my trunk settings, and I didn't use any policy route to control outbound traffc.
    If the issue still persist, please kindly share your configuration through pirvate messages.
    I'm very glad to check for you.
    Thank you
    Kevin
