How to see LAN infront USG20-VPN
So you need to use the advanced option in routing “Use IPv4 Policy Route to Overwrite Direct Route” and make a routing rule:
incoming interface
member LAN1
next hop
type gateway
IP of gateway router in front
SNAT none
You should if able to setup static route for the router in front with:
your LAN by Zywall 192.168.10.0 255.255.255.0
gateway to Zywall IP
If your not able to setup static route use SNAT outgoing-interface but you will then need NAT rules to forward ports.
Policy controls rule from WAN to LAN will be needed
Another option is to bridge WAN and LAN
incoming interface
member LAN1
next hop
type gateway
SNAT none
Thank you for your answer. I will try it tomorrow and check if I am able to make it work. Many thanks again.
- 217 Nebula Ideas
- 574 USG FLEX H Series
- 297 Service & License
- 473 News and Release
