Daily Log Report - msmtp: TLS certitifcate verification failed
I am trying to set up the daily log report but when I check the logs I get an info message saying:
msmtp: TLS certitifcate verification failed: unable to get local issuer certificate
I am using an outlook.com account as the log sender.
smtp-mail.outlook.com:587 TLS and STARTTLS are selected.
Hi @psilva
I checked the behavior by Gmail SMTP server. But it looks there is no this problem.
The mail server may have some security settings which will deny the SMTP requests
For Example, Gmail has some of the security setting.
In Sign-in & security, users must allow less secure apps. Otherwise SMTP request will been denied.
Hi @psilva
I tested on Microsoft mail server, the daily report still able send successfully.
The Authentication server function should disabled.
You can reference to my setting.
Zyxel_Stanley the authenticate server option was enabled. Thanks.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
