Disable Authenticate Client seting USG310
Domin
Domin Posts: 2
image  Freshman Member
Today, I thoughtlessly checked "Authenticate Client Certificates" in the web access settings Of course, I didn't save the certificate for myself beforehand and I turned off the option to log in without SSL.
Of course, the router doesn't allow itself to be pinged, so I don't even know what ports it has open.
I have physical access to it and I remember that the cetificate on self was still valid for a long time but I don't remember the date.
How to restore control?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 988
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    image  Zyxel Employee
    edited September 2022 Answer ✓
    Hi @Domin @homephixx,
    Please kindly log on Firewall via SSH and perform the following command.
    Router> configure terminal
    Router(config)# no ip http secure-server auth-client
    After that firewall won't check client's certificate.
    Thank you
    Kevin
  • homephixx
    homephixx Posts: 3
    I have been facing a similar issue and I could not figure t out. I just have reported it to the help center. Hopefully, it will soon get resolved. But, if you find any solution please share it here on the forum too. I will be really thankful.
  • Zyxel_Kevin
    Thank you
    Kevin
  • Domin
    Domin Posts: 2
    Thank you very much!
    It works! :-)
  • homephixx008
    homephixx008 Posts: 4
    Thank you do much for the solution.  :)
  • homephixx008
    Thank you so much for the solution. It is working.  :)
