Some question about the ATP
Username_is_reserved
in Security
Hi
I want to switch mine into "Live" Mode soon. Before that I can switch from the old Router to the ATP I need to setup something. Most work perfect. I just looking for a way to block Bad TLD like: .to, .li,... and other. Can I do that in the Contend Filter?
Hi @Username_is_reserved,
You can block TLD URL/Domain by URL keywords in CF profile.
Go to CONFIGURATION > Security Service > Content filter, and create a CF profile.
In Custom Service section allows you to block Web sites with URLs that contain certain keywords in the domain name or IP address.
Tick "Enable HTTPS Domain Filter for HTTPS traffic" for https domain filter.
Apply CF profile to Security policy.
Thanks for replay. Sorry I feel like a stupid idiot I cant get the Router to connect to the Internet.I guess I setup everythink like in the UTG. I must sett an Vlan ID.I add them into the Interface -> Vlan like in the USG to.PPoE is right. User + PW. I have no idea what could now be wrong.Any idea?Thanks0
Hi @Username_is_reserved,Please first make sure, that the router/modem in front of the USGs WAN interface is definitely in bridge mode.Depending on the provider and model you can already tag a VLAN on the bridge.Make sure, that you verify with your provider that the following details are correct:- Authentication Type- your user name and password- if compression is needed
sorry for the late replay!Please first make sure, that the router/modem in front of the USGs WAN interface is definitely in bridge mode.
Yes its just a dumb Zyxel DSL Modem
.VMG4005 https://www.zyxel.com/global/en/products/dsl-cpe/vdsl2-17a-bonding-and-35b-single-line-bridge-vmg4005-b50aThankfully I set a Vlan in the ATP and it works. "That" problem is fixed.Depending on the provider and model you can already tag a VLAN on the bridge.In ISP Account I add the neccecary Data and my ISP confirm the Information is rite.Make sure, that you verify with your provider that the following details are correct:- Authentication Type- your user name and password- if compression is neededMy ISP Told me that the not see in the logfile that the ATP is Dialing. So how can I check that? Does the Dialing process is before the Firewall?Thanks0 -
You can filter keyword "ppp" in debug category to see PPPoE dial process log.
MONITOR > Log > View Log
again sorry for the late replay:1 2022-09-23 23:28:20 debug Default pppd: Unable to complete PPPoE Discovery2 2022-09-23 23:28:20 debug Default pppd: Timeout waiting for PADO packets3 2022-09-23 23:28:13 debug Default pppd: Unable to complete PPPoE Discovery4 2022-09-23 23:28:13 debug Default pppd: Timeout waiting for PADO packets
The log indicated that no PADO response from ISP.
Device expect receive PADO packet from ISP in PPPoE discovery stage.
Following PPPoE flow for your reference.
Client <--------------------------> Server
-------------PADI----------->
<-----------PADO------------
------------PADR------------>
<-----------PADS------------>0 -
Hi thanks for replay. Where does I have to set such thinks?Zyxel_Cooldia said:Client <--------------------------> Server
Could the Modem have some problem?
It may need to confirm with ISP if they receive our device PADI packets to check where the packets lost0
Is there an E-Mail Adress for the Zyxel Support?
- 441 Beta Program
- 293 Service & License
