PPPoE fails after changing from ASDSL to VDSL (incl. modem) with Deitsche Telekom
Best Answers
Hi Christian,
thanks for your thoughts. Since I just changed from a sinple ADSL modem to Speedlink5501 as VDSL modem with the same ISP and credentials, I don't believe that thas is the reason.
Regards
Hartmut
Did you configured a VLAN tag @ your wanport
check this document
https://www.telekom.de/hilfe/downloads/octopus-f50-bng-adsl.pdf
5
in Germany there are some reseller for DTAG ISP credentials. i had the Feature, the username required a different character, that is for the type of VDSL in the string required to get connected.
in my case i had to add "H" for the 1st character in the username to get connected trough VDSL.
Regards
Christian0 -
Hi Christian,
Regards
Hartmut
check this document
5 -
Thanks, Mark, for your interesting hint. Might solve the problem. I have to leave confirmation to others since I decided to configure the 5501 as router with the USG40 as DMZ. Besides to the as reserved remarked TCP Port I had to omit UDP 10000. All other ports and GRE are passed to the DMZ. Not what I had in mind (another wrangling with the traffic) but it works.0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
