Windows 11 and securextender frequent disconnects
Having major problems with having a stable connection on a Windows 11 pro laptop. Have disabled wifi and using ethernet only. Connection disconnecting after 2 minutes almost every time using a BT router, continuous ping which is sub 6ms and a 30+ broadband connection.
Have re-installed client, rebuilt laptop, disabled AV from the Zywall directory, turned off firewall as a test. Also tried account from a seperate machine which is OK.
Hi @IanH,
Please kindly find the following FAQ to check if the symptom is the same.
https://community.zyxel.com/en/discussion/14013/ssl-vpn-disconnect-due-to-invalid-packet-size#latest
If the issue still , we can have remote session.
Looking forward to your update.
Thank you0 -
Fantastic, I will give this a try and will report my findings. Thank you for your assistance. 👍0
The packet size was set to 1374, the issue is the firewall is on an earlier version of firmware
Every time, I try and install the firmware it fails. I have a workaround of setting up a ping but need to work out how to update.V5.30(ABAR.0) / 2022-04-20 01:43:59 0 -
Hi @IanH,
We have several SSLVPN issue on 5.30 .
Did you have any error meassage when the upgrade failed?
Kevin0 -
Hi Kevin, no error, showing after the update. Just the version is not changing from V5.30(ABAR.0) and then next log on, the update appears again.0
Hi @IanH,
Could we have the remote session to check the firmware upgrade issue ?
We can start at 15:00 (UTC+8). Please kindly provide the remote information and available time via PM.
Thank you.0
- 441 Beta Program
- 294 Service & License
- 461 News and Release
