Zyxel DHCP client does not honour NO DNS
Zywall 110 V4.72(AAAA.0)ITS-22WK28-r104687
USG60 V4.72(AAKY.0)ITS-22WK35-r105124
Come across this bug where a Zywall 110 running the DHCP server has no DNS IP set for clients and a USG60 as DHCP client receives the offer and ACK with no DNS IP yet the USG60 puts in a DNS IP for Domain Zone Forwarder in config > system > DNS of the gateway IP of the DHCP server when I do not want it too.
Is thier a way to stop this? Thanks
Hi @PeterUK,
The issue can be reproduced in lab test.
We are checking internally, please wait for my update.
It be nice to disable any added DNS to Zywall so that the Zywall has to do lookups by recursion root servers.
As confirmed, if DHCP server does not provide DNS server option to gateway, gateway will take server identifier as default DNS server. This network scenario is relatively rare in practice. We would suggest to set up static IP on WAN interface and manually add DNS zone forwarder for your network.0
But the Zywall can do DNS without adding a DNS in Domain Zone Forwarder which is what I want you can test this yourself with static IP which is what I'm doing as a backup DNS but was looking to do DHCP for some interfaces.
Do you want zywall to do DNS lookup by recursion root servers assuming the DHCP server does not provide DNS options?
Yes without any added Domain Zone Forwarder0
Hi @PeterUK,
Could you share more information about this scenario in practice.
Just wondering about why you need gateway to do the DNS query by recursion root servers?
Because why not? I have a bind setup doing this but should that system go down I fail over to the USG60 to do the DNS
Hi @PeterUK,
Thanks for your feedback, i will post this to ideas section.
https://community.zyxel.com/en/discussion/14615/zyxel-dhcp-client-does-not-honour-no-dns/p1?new=1
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 463 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 440 News and Release
- 4.3K FAQ
- 91 Security Highlight
