Maximum number of address objects that can be created on the Zyxel VPN100
bbp
bbp Posts: 68  Ally Member
First Answer First Comment Friend Collector Sixth Anniversary
What is the maximum number of address objects that can be created on the Zyxel VPN100?
  • Zyxel_James
    Zyxel_James Posts: 788  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @bbp,
    For Zyxel VPN100, the maximum number of address objects is 300.
    Please refer to VPN100 User Guide Appendix B Product Features.
    VPN100 User Guide
    Thank you.
    James
  • Zyxel_James
    Hello @bbp,
    VPN100 User Guide
    Thank you.
    James
  • bbp
    Thank you for the answer James.
    I must say though, that's surprisingly low number, given the number of max firewall ACLs which is 500.
