Mac address filtering on ATP/USG
DiegoF
DiegoF Posts: 4 image  Freshman Member
Friend Collector
edited July 2024 in Security Ideas
it would be very useful to be able to create security policies based on mac address objects. In Zyxel firewall there is no possibility to create mac address objects like in other vendors firewall. Is this a feature you plan to implement on your firewalls as well?
2 votes
Active · Last Updated
  • dpipro
    dpipro Posts: 73 image  ZCNE Certified
    First Comment Friend Collector Sixth Anniversary ZCNE Switch Level 1 Certification - 2020
    Hello @DiegoF
    as a workaround you can configure IP/MAC binding to specify a fixed IP to each MAC address.
    Best regards
    Best regards
  • DiegoF
    Friend Collector
    Hello @dpipro
    thanks for the suggestion, for a small enviroment your workaround it's ok but i need this feature for deploying firewall in school with hundreds of student's device
    Best regards
    PeterUK Posts: 4,268 image  Guru Member
    Why not use a switch?
  • DiegoF
    Friend Collector
    the need is for wireless client, many hundreds
  • dpipro
    Hello @DiegoF
    you can configure a dedicated wireless SSID for students with an associated VLAN in a different subnet. With this configuration you can isolate the students network from the LAN and you can add security policies for them. What you think?
    Best regards
    That does not stop from using a switch for MAC filtering you can go from  ATP/USG  to switch to AP or you can get a AP with filtering.
  • Nazareno
    Nazareno Posts: 2 image  Freshman Member
    Hi, i'm looking for the same issue.. I need to create mac address filter on dhcp, so only authorized MAC address can connect to the lan...
    edited October 2022
    You can do this in the VPN300
    However this does not stop DHCP from getting a IP by DHCP....
