USG 40 throughput
thanks. Can I copy my USG40 config to the USG FLex 100?
Configuration should be converted, AFAIK.(at time of writing, a placeholder pace is deployed).
The converter tool(https://convert.cloud.zyxel.com/) is maintained now, it shall be back before 9/9/2022, thanks
Got a 100 flex and I used the converter. Work great. Except, the WAN connection. But I used wizard to sort out.However, I have some questions:1.) Do I need to enable IP/MAC binding on my ISP (xfinity) interface?2.) anti-malware: what is recommend, express or stream mode?3.) is there an easier way to select geo fencing than adding countries manually? e.g. more a checkbox menu.0
Hi @tesagig(1).You won’t enable IP/MAC binding on USG Flex100 with the ISP, we usually configure IP/MAC binding on LAN interface to bind the LAN hosts(e.q. internal web server, NAS server, etc.) to fix their internal DHCP IP addresses.(2). It depends on your requirement. The Express mode is a cloud query based Anti-Malware detection, the USG Flex 100 will scan files by sending each file’s hash value to a cloud database via cloud query.As for the Stream mode, it is signature based Anti-Malware detection, the USG Flex 100 will scan all files for viruses using its anti-malware signatures to detect known virus patterns.(3). Currently, we only support adding a Geo IP address object at one time on the Web-GUI. But not sure the CLIs whether would be faster for you, please refer to the below CLI:Router# show geo-ip country-code (To look up the country code.)Router# configure terminalRouter(config)# address-object US geography US allRouter(config)# address-object China geography CN allRouter(config)# address-object Germany geography DE allThen there are three Geo IP objects on your USG Flex 100 device.The below no CLIs would remove those Geo-IP objects.Router(config)# no address-object GermanyRouter(config)# no address-object USRouter(config)# no address-object ChinaBesides, because those further questions are not related to the original title, so we encourage you could create a new discussion the next time, which can help other people who encounter similar questions like yours to find the answer more easily.0
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 387 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
