Armour G5 Turn on WiFi bands individually
lslqtz
in Home Router
Hi, I would like to ask if it is possible to turn off the 2.4Ghz band and use only the 5Ghz band.
Hello @lslqtz
The user guide is able to be downloaded from https://www.zyxel.com/uk/en-gb/support/download?model=armor-g5-nbg7815
It is not clear from the user guide whether the 2.4GHz band can be turned off to leave the 5GHz band on.
Kind regards,
Tony0 -
Hi @lslqtz
Thanks for the feedback.
The wifi bands could use the individual name on 2.4GHz and 5GHz.
The feature to turn on/off wifi bands individually is not available on the Armor series.
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
