USG-60 - On VPN SSL I have "Error 0x800b0109 authenticating server credentials! (0x0)"
Hi
As in subject, followed all instructions found here with no success.
If I reboot USG it works fine and for some days everything is fine but after a while if I try to reconnect I get error again
Is there a way to solve this?
Best regards
Best regards
[ 2022/10/09 10:44:15 ][SecuExtender Agent][DETAIL] Build Datetime: Jan 25 2021/13:07:58
[ 2022/10/09 10:44:15 ][SecuExtender Agent][DEBUG] SecuExtender.log: C:\Users\SP\SecuExtender.log
[ 2022/10/09 10:44:15 ][SecuExtender Agent][DEBUG] osvi.dwPlatformId = 2, osvi.dwMajorVersion = 6, osvi.dwMinorVersion = 2
[ 2022/10/09 10:44:15 ][SecuExtender Agent][DEBUG] interface guid: {DF6DF3CF-7DE3-4ECA-B72E-10800A3B1305}, idx: 14
[ 2022/10/09 10:44:15 ][SecuExtender Agent][DEBUG] tBuf : (\DEVICE\TCPIP_{DF6DF3CF-7DE3-4ECA-B72E-10800A3B1305})
[ 2022/10/09 10:44:15 ][SecuExtender Agent][DEBUG] network name got, idx: 15
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Checking service (first) ...
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] SecuExtender Helper is running
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Try to connect to SecuExtender Helper
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] SecuExtender Helper is connected
[ 2022/10/09 10:44:29 ][SecuExtender Agent][INFO] [stefano] try to login 37.119.61.176:7443
[ 2022/10/09 10:44:29 ][SecuExtender Agent][INFO] Connect to 628571568:7443
[ 2022/10/09 10:44:29 ][SecuExtender Agent][INFO] Local address is 3232236011
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DEBUG] Connect success.
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 0
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] 1270 bytes of handshake data received
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x90312
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Send 93 bytes of handshake data
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 1
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] 51 bytes of handshake data received
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x0
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] SSL Handshake is successful
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] STREAM_SIZE: Header: 13 Trailer: 16, MaxMessage: 16384
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Protocol: TLS1.2
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Cipher: AES256
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Cipher strength: 256
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Hash: SHA384
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Hash strength: 0
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Key exchange: 0xae06
[ 2022/10/09 10:44:29 ][SecuExtender Agent][DETAIL] Key exchange strength: 255
[ 2022/10/09 10:44:29 ][SecuExtender Agent][INFO] Server subject: CN=usg60_B8ECA3AE77DA
[ 2022/10/09 10:44:29 ][SecuExtender Agent][INFO] Server issuer: CN=usg60_B8ECA3AE77DA
[ 2022/10/09 10:44:29 ][SecuExtender Agent][ERROR] **** Error 0x800b0109 authenticating server credentials! (0x0)
[ 2022/10/09 10:44:31 ][SecuExtender Agent][DETAIL] SSL session is created
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DEBUG] SSL Connection is going to be closed
[ 2022/10/09 10:44:32 ][SecuExtender Agent][INFO] user login device success
[ 2022/10/09 10:44:32 ][SecuExtender Agent][INFO] Creating secure tunnel to 37.119.61.176:7443
[ 2022/10/09 10:44:32 ][SecuExtender Agent][INFO] Connect to 628571568:7443
[ 2022/10/09 10:44:32 ][SecuExtender Agent][INFO] Local address is 3232236011
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DEBUG] Connect success.
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 0
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] 1270 bytes of handshake data received
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x90312
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] Send 93 bytes of handshake data
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 1
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] 51 bytes of handshake data received
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x0
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] SSL Handshake is successful
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] STREAM_SIZE: Header: 13 Trailer: 16, MaxMessage: 16384
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] Secure session is created
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] Secure session negotiation begin
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] stage 1...done
[ 2022/10/09 10:44:32 ][SecuExtender Agent][DETAIL] stage 2...done
[ 2022/10/09 10:44:33 ][SecuExtender Agent][WARN] The device is going to close the connection.
[ 2022/10/09 10:44:33 ][SecuExtender Agent][ERROR] stage 3...failed (0x0)
[ 2022/10/09 10:44:33 ][SecuExtender Agent][ERROR] Failed to create security tunnel (0x0)
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DEBUG] SSL Connection is going to be closed
[ 2022/10/09 10:44:33 ][SecuExtender Agent][INFO] Connect to 628571568:7443
[ 2022/10/09 10:44:33 ][SecuExtender Agent][INFO] Local address is 3232236011
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DEBUG] Connect success.
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 0
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] 1270 bytes of handshake data received
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x90312
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] Send 93 bytes of handshake data
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 1
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] 51 bytes of handshake data received
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x0
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] SSL Handshake is successful
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] STREAM_SIZE: Header: 13 Trailer: 16, MaxMessage: 16384
[ 2022/10/09 10:44:33 ][SecuExtender Agent][INFO] logout message has sent
[ 2022/10/09 10:44:33 ][SecuExtender Agent][DETAIL] Connection ends.
Hi @sp_pd,
1)Did you have the latest weekly firmware , please see the below link to find the latest.
https://community.zyxel.com/en/discussion/14386/zld-v4-72-wk35-firmware-release#latest
2)Did you have any error firewall log when disconnected ?
Kevin
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
