ES3500-24HP
adequate
adequate Posts: 1 image  Freshman Member
Good-day
I have a Zyxel ES3500-24HP, i want use it for CCTV ,the problem is the switch is not powering more than 11 POE Cameras.
Once new port are connected one port shut down .
What can i do to correct this?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @adequate,
    Welcome to Zyxel community!
    This is because you are using PoE classification mode which will reserve the power to each connecting PD.
    Please go to Basic setting > PoE status > PoE setup and select the consumption mode.
    Zyxel Melen
