Product Poe12-30W and the LED "Poe" Blinking, what is the problem
Pejen
Pejen Posts: 1 image  Freshman Member
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    edited October 2022
    Hi @Pejen,
    Welcome to Zyxel community!
    The PoE LED will blink when the PoE 12-30W does not connect with PD. It is because the PoE 12-30W is detecting the PD.
    Once you connect a PD, it will turn to steady green.
    Zyxel Melen
