Use Zywall only as AP controller
fishymagnus
We are getting a new firewall, I want to keep our Zywall and use it as a controller for our ~15 AP points`only. Will the zywall connect to the wireless points if I give it a new IP-address where it is no longer the gateway in the wifi-management network?
Hi there,
If Zywall get a new IP-address, it still can connect to the access points.
You can go to Configuration >> Network >> Interface >> Ethernet/ VLAN
Click Advanced >> Add/ Edit >> Type the Zywall new IP at First IP Adress >> Click OK
Through the IP setting, it can fix the AP Controller.
Zyxel_Judy
Hi there,
Zyxel_Judy
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
