which one to choose?
DR_SERVIZI
could you give me a hand for a quote to do for a customer relating to a firewall that performs the following functions: - 2 separate LAN IPs (LAN1 x OFFICE SWITCH 192.x.x.x and LAN2 x GUEST SWITCH 122.x.x.x) - 2 WAN with load balancing or bonding and failover backup operation (WAN1 x FIBRA ESTRA proprietary router not modifiable and WAN2 x FIBRA TIM proprietary router not modifiable) - Optional VPN in case it is to be implemented at a later time (perhaps with a setup program to be sent to the external client PC to make the connection ready by installing it)
Welcome to Zyxel community. According to your requirement, we suggest you could choose UGG Flex 200/500/700 or ATP 200/500/800 models and you can refer to this (Where to Buy) link to see which channel you can contact to purchase our product. Thanks
.0 -
Or VPN100/300 unless they EOL before Flex/ATP?0
Personal opinion...
Also USG Flex 100 allows three "internal" LAN ports + 2 WAN ports (one is configurable and is on port 5) for allowing the same configuration. Less bandwidth among Ports/lan segments, but anyway can fit the challenge.
Unless one or both WAN connections allows more than 500mbps each. Therefore, maybe USG 100 Flex might be on the short side.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
