USG 1100 - DHCP issue - stops serving IP addresses
@Zyxel_Kevin about 2 days after installing the new firmware, the DHCP server has stopped working again:
Router> debug system ps | match "dhc"24561 1 dhcpcd_request root ? 19 0 0.0 0.0 Ss 2028 516 364 507 08:26:26 08:23:02 00:00:26 /usr/local/sbin/dhcpcd_request eth0 0 ZyWALL 11024595 1 dhcpcd root ? 19 0 0.0 0.0 Ss 1836 492 296 459 08:26:37 08:22:51 00:00:00 /sbin/dhcpcd -R -Y -N -G -L /var/zyxel/zysh/ -i ZyWALL 110 -h EBCzywall110 eth0Router>0 -
Hi @RobT,
Please kindly find the inbox, I sent you the fix yesterday.
Plesae feel free to contact us if the issue persist.
Kevin0 -
@Zyxel_Kevin I upgraded the firmware to 4.72(AAAA.0)C0 and the router started to experience DHCP issues again where it would no longer serve out IP addresses. I reinstalled V4.72(AAAA.0)ITS-22WK20-2022-05-23-220500939 but the DHCP server also stops working after about a day.0
@mMontana Thanks for your quick reply! @Zyxel_Kevin sent me V4.72(AAAA.0)ITS-22WK20-2022-05-23-220500939 after he remotely logged into the router and found that the App-watch-dog needed a 3 minute interval to check daemons. When I upgraded to V4.72(AAAA.0)ITS-22WK20-2022-05-23-220500939 from V4.71 the DHCP server worked correctly until it was upgraded to V4.72 (AAAA.0) when it started to exhibit the DHCP problem again.1
@Zyxel_Kevin After upgrading to the latest weekly firmware, I'm still experiencing DHCP issues where it stops serving out IP addresses.0
Is your subnet bigger then 255.255.255.0 ?
I had issue also with USG40 and a "bigger than /24" subnet mask + lease interval.
https://community.zyxel.com/en/discussion/comment/9232
Any updates on this?0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
