which one to choose?
DR_SERVIZI
DR_SERVIZI Posts: 1 image  Freshman Member
edited October 2022 in Security
could you give me a hand for a quote to do for a customer relating to a firewall that performs the following functions:
- 2 separate LAN IPs (LAN1 x OFFICE SWITCH 192.x.x.x and LAN2 x GUEST SWITCH 122.x.x.x)
- 2 WAN with load balancing or bonding and failover backup operation (WAN1 x FIBRA ESTRA proprietary router not modifiable and WAN2 x FIBRA TIM proprietary router not modifiable)
- Optional VPN in case it is to be implemented at a later time (perhaps with a setup program to be sent to the external client PC to make the connection ready by installing it)
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Welcome to Zyxel community. According to your requirement, we suggest you could choose UGG Flex 200/500/700 or ATP 200/500/800  models and you can refer to this (Where to Buy) link to see which channel you can contact to purchase our product. Thanks :) .
    PeterUK Posts: 4,429 image  Guru Member
    edited October 2022
    Or VPN100/300 unless they EOL before Flex/ATP?
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Personal opinion...
    Also USG Flex 100 allows three "internal" LAN ports + 2 WAN ports (one is configurable and is on port 5) for allowing the same configuration. Less bandwidth among Ports/lan segments, but anyway can fit the challenge.
    Unless one or both WAN connections allows more than 500mbps each. Therefore, maybe USG 100 Flex might be on the short side.
