Pros/cons in blocking GEO locations from inbound - other use of GEO fencing?
Hi @tesagig,
If you have a public service and can only connect from your or specify country ,you can use the function to limit.
It is not recommended to apply to outbound traffic otherwise there will be many sites unavailable
All sceniaro have different settings , all depend on your needs.
We can provide the settings advice if you could me the sceniaro.
Thank you
Kevin
thanks. I don't have any service that need to connect to USG, other than when I travel; e.g. for security video. Maybe VPN soon.So, my thinking was to lock down problem countries that I don't travel to. e.g. Most of Asia, Russia, ....0
Hi @tesagig,
Please reffer the following settings to block traffic to Asia.
1) Create the GEO objects.
2) Create the rule on top , src:internal dst:GEO_ASIA act:Deny.
Then traffic from LAN to Asia will be blocked.
Thank you
Kevin0
- 588 USG FLEX H Series
- 477 News and Release
