Ghost traffic
I cannot access a service/port when the firewall (security policy) is enabled, but the traffic goes through when it is disabled.
However, I cannot see the traffic entry in the logs so I can whitelist it and reenable my firewall.
Kindly advise
Model: USG1100
Kindly advise
Model: USG1100
Hi @nacho,The asymmetric route led to the issue.Create a policy based route on the L3 device where under the firewall to ensure the return traffic through the firewall.The issue was resolved. Thanks your time.Kevin0
Hi @nacho,
Please check you don't have the rule such like Src:LAN DST:WAN ACT:Block
And kindly provide your configuration via Private Message.
I'll check and give the advice.
Thank you
Okay i will send the configuration.
Actually it is WAN to DMZ0 -
Hi @nacho,
I saw each WAN to DMZ rules have restricted destination IP.
If only specific address cannot pass , please check you have the rule for the destination addresses.
If the issue still we can have the remote session and please send your available time.
Thank you
Kevin
Hi @Zyxel_Kevin
We can do on Friday(04/11/2022) - 9am gmt+10 -
- 441 Beta Program
- 292 Service & License
