[eITS#200700296, 220700648] When DNS TTL of FQDN object for destination IP timeout, the video stream
PeterUK
edited October 2022 in Security
So have not tested the policy control for this fix if it fixes it because I need that for USG60 but what I have tested is BWM on the VPN 300 with the new firmware V5.32 and it buffers when TTL goes to 0 and then is removed the for like *ttvnw.net for Twitch video like:
https://www.twitch.tv/twit
It is then set for BWM to Guaranteed Bandwidth
inbound 71680kb
outbound 3200kb
interface WAN 9280kb
interface DMZ 92160kb
When there is lots of downloading going on P2P all seems fine the video plays fine then the TTL goes to 0 that the video stream is using then this gets removed and the video buffers because lack of bandwidth and because it drops out of BWM Guaranteed Bandwidth.
Can this be fixed so the IP is still in the Guaranteed Bandwidth on active session?
Best Answers
  • Zyxel_Stanley
    Hi @PeterUK
    The video stream blocked reason is because the firewall reapplied FQDN object IP again since DNS cache flushed.
    Extending the DNS cache may have security concern it is because it may result a new IP address. So We will add a workaround in ZLD4.73 firmware for specific scenario.
    It could stop flush old session, then system will keep the session even the DNS cache is expired.
  • Zyxel_Stanley
    Hi @PeterUK
    Without WILDCARD FQDN: Allowing port 53 and 443 from LAN to WAN.
    --> Allowing port 53 & 443 traffic from LAN to WAN and without any limitation.
    With WILDCARD FQDN:  Allowing port 53 and only WILDCARD FQDN for port 443 from LAN to WAN
    --> Allowing port 53 & 443 traffic from LAN to specifc IP addresses but blocks othres.
    For security concern, firewall will flush FQDN IP sessions once FQDN DNS TTL is expired.
    In 4.73 firmware will have workaround to keep old sessions.
  • Zyxel_Stanley
    Hi @PeterUK
    edited October 2022
    Great can't wait but the test I did was for BWM on VPN300 not the policy control firewall so I hope it fixes both.
    edited October 2022
    I also do not see how its a security concern if the same session is still going long after the TTL goes to 0 and the IP is flushed.
  • Zyxel_Stanley
    Hi @PeterUK
    If the old IP address used by attacker, and whom known public IP address, then it may attack your PC from Internet. (it is because the NAT session table still exist on firewall)
    edited October 2022
    Well that true when not using FQDN you allow port 443 outgoing the attacker knows your public IP the NAT session table still exist on firewall.
    Just to break it down why I see no problem should I of missed something
    Without WILDCARD FQDN just allowing port 53 and 443 from LAN to WAN
    You DNS to go to Twitch
    You DNS to get the video stream IP 185.42.206.83
    You continue to stream video under the same session long after DNS TTL to 0
    With WILDCARD FQDN just allowing port 53 and only WILDCARD FQDN for port 443 like *Twitch and *ttvnw.net from LAN to WAN
    You DNS *ttvnw.net to get the video stream IP 185.42.206.83
    You should be able to continue to stream video under the same session long after DNS TTL to 0 and IP is removed.
    So I just don't see the harm in allowing a session that was trusted at the start and then if you simply allow port 443 outright maybe if session closes and opens another session from another source port I could see it being a problem?
  • Zyxel_Stanley
    Hi @PeterUK
