How to reach an external server on a USG1100 firewall
Matt10669
Matt10669 Posts: 20  Freshman Member
Zyxel Certified Network Administrator - Security First Comment Second Anniversary
Hi, I need to reach an external server (IP 20.103.254.144) through the ports 80 and 443 of a USG1100 firewall from the clients of my LAN. At the moment the firewall blocks the outgoing flow. I found lot of guides about NAT service for incoming packets to an internal server but nothing about the opposite. I have to go out from LAN to WAN. Any explanations or helps will be very appreciated.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    edited October 2022
    Hi @Matt10669,
    Can you see any blocked log at MONITOR > Log > View Log when filtering keyword "20.103.254.144"?
    PeterUK Posts: 3,889  Guru Member
    edited October 2022
    By default LAN to WAN is all allow out by policy control, do any clients of your LAN have internet access?
  • Matt10669
    All my clients have internet access. I forgot to mention that in my LAN we have configured 2 VLAN's. I dont know if this can be important
  • Hi @Matt10669,
    Thanks for Sharing Really Appreciated.....
  • Zyxel_Cooldia
    Hi @Matt10669,
    Please help to test access 20.103.254.144 again and capture packets on USG1100 wan interface.
    We would like to check why it is fail to access.
    MAINTENANCE > Diagnostics > Packet Capture.
    Interface = External wan interface
    Host IP =
    20.103.254.144
    Download packets in "Files" tab and send me in PM for further analzying.
  • Matt10669
    I checked and I don't have any block in the log monitor. But the service doesn't work. If I connect my lan directly into the router bypassing the firewall the service works. Very strange
  • Matt10669
    Cooldia I've sent you what you asked. Thank you so much
