NXC500 with WAX630S
ThomasG
ThomasG Posts: 2  Freshman Member
edited May 2024 in Wireless
we have an NXC5500. Now the new WAX630S are not recognized.
The WAX630S is not included under firmware either.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Guru Member
    Hi there,
    Each kind of AP Controller can support some kind of APs. Note that NXC5500 doesn’t support to manage WAX630S.
    You can refer to USG FLEX/ ATP/ VPN models to manage WAX630S. Moreover, we also provide a cloud-based network management platform called Nebula that can manage almost Zyxel products. Please refer at this link to experience the new way to manage your devices: https://nebula.zyxel.com/
    Zyxel_Judy
    Untitled Image
  • ThomasG
    Thanks for the feedback. Will it also be possible with the NXC5500 soon? Firmware update?
    Thanks.
  • Zyxel_Judy
    Hi there,
    It'll be impossible with the NXC5500 to manage WAX630S. Controller with support list in maintenance mode refer to this link AP Controller Technology - Supported Models | Zyxel Networks
    Zyxel_Judy
    Untitled Image
