How to reach an external server on a USG1100 firewall
Hi, I need to reach an external server (IP 20.103.254.144) through the ports 80 and 443 of a USG1100 firewall from the clients of my LAN. At the moment the firewall blocks the outgoing flow. I found lot of guides about NAT service for incoming packets to an internal server but nothing about the opposite. I have to go out from LAN to WAN. Any explanations or helps will be very appreciated.
Hi @Matt10669,
Can you see any blocked log at MONITOR > Log > View Log when filtering keyword "20.103.254.144"?
By default LAN to WAN is all allow out by policy control, do any clients of your LAN have internet access?
All my clients have internet access. I forgot to mention that in my LAN we have configured 2 VLAN's. I dont know if this can be important
Hi @Matt10669,
Can you see any blocked log at MONITOR > Log > View Log when filtering keyword "20.103.254.144"?0 -
Hi @Matt10669,
Please help to test access 20.103.254.144 again and capture packets on USG1100 wan interface.
We would like to check why it is fail to access.
MAINTENANCE > Diagnostics > Packet Capture.
Interface = External wan interface
Host IP = 20.103.254.144
Download packets in "Files" tab and send me in PM for further analzying.
I checked and I don't have any block in the log monitor. But the service doesn't work. If I connect my lan directly into the router bypassing the firewall the service works. Very strange
Cooldia I've sent you what you asked. Thank you so much
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
