SSL VPN Not Working Post ATP200/800 Firmware Upgrade
Hi @NEP
It is the same symptom on eITS#220701020, on v.5.30 firmware you can establish an SSL VPN connection via the device Web-GUI port and SSL VPN server port as well. Once you update to v.5.32 firmware, only can use the SSL VPN server port to establish SSL VPN, such as the below specific port 9998.
The default port is still 443 in v.5.32 firmware.
Thanks.0 -
@Zyxel_Jeff Thanks for the explanation. Don't recall seeing a clear indication of this in the Release Notes. Seems like quite a breaking change. Then again, I suppose this is more related to an incorrect configuration in the original setup. You guys can't be expected to know all the configurations in-use. Is it safe to assume that you recommend using different ports for HTTPS and SSL VPN access? Thanks!
@Zyxel_Jeff Or is that what "[Bug Fix] eITS#220500690 a. Fix: SSLVPN service port keeps using the original port after manually customized it" indicates?
NEP said:@Zyxel_Jeff Or is that what "[Bug Fix] eITS#220500690 a. Fix: SSLVPN service port keeps using the original port after manually customized it" indicates?
Thanks.
@Zyxel_Stanley Thanks for the "Best Practices" link. We had Trusted IPs and Geolocation set up and I separated the HTTPS and SSL VPN ports yesterday. I'll peruse that page when I get a chance. Please consider this matter closed. Thank you!
NEP OK, you are welcome
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 293 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 408 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
