HTTPS login from lan
is it possible to enable https login from lan?
I found this https://support.zyxel.eu/hc/en-us/articles/4403947447186-USG-USG-FLEX-ATP-VPN-How-to-allow-HTTPS-Web-GUI-Access-from-WAN-, but after following the steps and applying them to the lan it changes nothing except showing other port after IP adress (https://192.168.XXX.XXX:XXXXX/).
I would like to disable http(no s) completely, but then I wont be able to login inside atp administration.
Hi @samba,
1)Please kindly check you have enabled HTTPS at service control.
2)Please kindly check you have the following rule and there is no related block rule before it.
Please feel free to contact us if still have concerns.
I'm very glad to help you. Thank you
Kevin0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
