How to reset/connect to NWA1123-AC
I have tried to reset the NWA1123-AC using the reset button and the 30-30-30 method. The AP shows SSID ZYXEL, and WiFi can connect, but it doesn't provide an IP using DHCP.
I have connected to the AP using the wired ethernet and the AP responds to a ping at 192.168.1.2, but I cannot connect either using HTTP or SSH.
How can I reset the NWA1123-AC to factory defaults so that I can reconfigure it?
Hi @Mile_E
If you have pressed the reset button for 10~15 seconds and saw the first LED light blink the red light for a few seconds, you have reset the AP. And please wait for the AP boot. Based on the AP status, you can wait for 5 minutes and ping 192.168.1.2.
If the AP has responded, you can try to use SSL and HTTP to login..
If it can’t still go to the Web GUI, please help us do the RMA process.
Here is our RMA information.
Jay
No red light. When I press the reset, the light flashes yellow, then restarts and flashes green.I'm not the original purchaser; RMA probably not possible.0
Hi @Mike_E
Please try to use our tool ZON.
Here is the downloadlink:https://www.zyxel.com/tw/zh/products/management-and-reporting/zyxel-devices-installation-tool-zon-utility
And here is the article to talk you how to use the ZON tool
https://community.zyxel.com/en/discussion/12598/how-to-use-zon-to-configure-zyxel-device-basic-setting
Please use the ZON tool to check the AP IP, and use the browser to connect Local GUI.(http://AP IP)
Because the NWA1123-AC has been launched for serval years.
If it still can't detect by ZON or connect to the local GUI, the device might be faulty.
You can consider our AX series access point for enjoying new and fast wireless protocol.
Jay
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
