Delete USG20W-VPN unused SSID
Device installed during 2019 with 4.x firmware. Works nicely. Has 4 SSIDs configured.
Item #1 maybe is born with the device. Was not interested, left it there.
Item #2 and #3 were created by me on ZLD 4 firmware.
Item #4 maybe arrived with later update.
Button Add works, but tells me "too many SSIDs". Fine.
No delete button. No delete option into SSID details.
Am I missing something?
Hi @mMontana,
Thanks for issue report. Maximum SSID profile should be 4.
The "Add" button doesn't make sense. We will discuss internally, and update status on this thread0 -
Is necessary to discuss simply adding a called "remove" or "delete"?I mean: already senseless to forcely have 8 different profiles into APs (which can be disabled but not deleted).0
Hi @mMontana,
Per checked, 4 SSID profiles is mainly for quick setup wizard. that's why there is no delete on that page.
IMO, if there's an "add" a "delete/remove" is needed.0
Up. Any updates?
Thanks for feedback.
Considering its related to quick setup wizard, and there is no major issue in the current design, we are more prone to stay at the current design.
- 390 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 51 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 220 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
