VPN dashboard wrong (5.32)
The device has 4 VPN Gateways
two are site to site, client role. Two are dynamic peer to site, server role.
4 connections are setup.
One up and running, other three (with related gateways) are disabled and unconnected.
Neverthless...
I have a "top 5 DPD fail" and "top 5 connectivity fail" for disabled gateways and connection.
So this is not correct, nevertheless not totally wrong.
However.
how on earth, or under which chemical substance the software tells me that there are two site to site tunnels connected?
Seriously?
Hi @mMontana
This symptom fixed in ZLD5.32 firmware.
Please have a try to upgrade to latest version and check if it is helpful.0 -
As my experience is not fixed.I've seen the issue after updating to 5.32.I am not aware if it was present before the update.I verified with two different browser, opening the interface after enabling inPrivate/Incognito mode.
Hi @mMontana
The symptom doesn't happen in my test result. I will send you private message for further check.0 -
Up.Link for diagnostic data sent few days ago.File still wasn't downloaded.Any news?0
Hi @mMontana
We need your help to arrange remote HTTPS conenction for further check this issue.
If it is possible, please forward it by private message to me.
As answered the first time, customer did not allow me to remote connection. I'll try again for permission but I'm not confident for a positive outcome
Answer for remote access is "no" and it's final.
Update.
Counter reached 420 VPN connections out of 20 max available; in fact, there was only one Site-to-site connection enabled and nailed up; firmware was still 5.32 as screenshot, standby partition contained 5.32WK41.
The only connection worked everytime, maybe the counter got up anytime it falled and back up; I was trying to add a VPN connection on the same gateway and was not working.
Rebooted with 5.32WK41.
Now I re-created the same VPN connection on the existing gateway it from scratch and started at first shot (I tried hard to understand why it was not working).
Need to try to re-add also some other objects that are needed, standby partition was updated several weeks ago but never rebooted the firewall.
Anyway, I'll keep posted for updates.
After more than 100hrs of uptime, the VPN count is stable.Even if a connection is forcely closed (1 gateway, 2 connections/subnets), the VPN count is kept consistent (only 2 tunnels).Still on 5.32 WK41 firmware..0
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
