Setup switch spanning VLAN with XGS1930 series
I would like to use a fibre connection between two XGS1930 switches to transport two logical networks separated by VLAN:
Or described in other words:
All data on port 24 of the left switch (1) belong to VLAN2 (switch should tag them accordingly).
All other ports (except SFP+ port 28) belong to VLAN1 (default network).
The fibre connection between switch 1 port 28 and switch 2 port 52 should transport frames of both VLANs.
Switch 2 routes packets of VLAN2 to ports 19-20, all other packets (VLAN1) to the other ports.
So far I have only configured port based VLAN on one switch only using the setup wizard...
Can anyone give me a hint how to configure the scenario described above? What VLAN type and VLAN registration is necessary? Do I need to enable VLAN Trunking? Ingress check?
Thank you very much in advance for your help!
Florian
Florian
Hi @Zyxel_Melen,
last weekend I tried the suggested setup. Configuring switch 1 went well but during the configuration of switch 2 I was suddenly locked out (no access to switch 2 anymore) and had to restart the switch(es) to reload the previous settings.
It worked after I had changed the settings to the following (changed settings are in bold):
Just for reference the diagram first (unchanged):
Switch/Port VLAN1 Control &
TaggingVLAN2 Control & Tagging PVID Switch 1 - Port 24 (Router2) Normal
untaggedFixed
untaggedPVID 2 Switch 1 - Port 28 (Connection to Switch2) Fixed
untaggedFixed
taggedPVID 1 Switch 1 - all other ports Fixed
untaggedNormal
taggedPVID 1 Switch 2 - Port 19, 20 (VLAN2 devices) Normal
untaggedFixed
untaggedPVID 2 Switch 2 - Port 52 (Connection to Switch1) Fixed
untaggedFixed
taggedPVID 1 Switch 2 - all other ports Fixed
untaggedNormal
taggedPVID 1
I hope this finally makes sense. I got on the right track after I googled "Zyxel TX Tagging" and found an official VLAN-Tutorial.
Best regards
Florian0
Hi @fquadt,
Welcome to the Zyxel community!
Does the router2 a VLAN-aware device?
If yes, you can
1. Add your LAN interface with a specific VLAN tag (VLAN 2) for your network2.
2. Switch 1 ports 24 & 28 fix to VLAN 2. Both ports should be tagged.
3. Switch 2 ports 19 & 20 & 52 fix to VLAN 2. Port 19 & 20 should be untagged and port 52 should be tagged.
4. Set PVID 2 to switch 2 ports 19 & 20.
If not, you can
1. Fix switch 1 port 24 to VLAN 2 and forbid VLAN 1. Port 24 should be untagged here.
2. Also, set the PVID 2 to switch 1 port 24.
Zyxel Melen0 -
Hello Melen,
thank you very much for your detailed instructions!
The router2 is not VLAN-aware. I tried to follow your instructions accordingly.
To make sure I made the correct settings, allow me to insert some screenshots after every step you described. Am I right that all settings have to be made in the "Static VLAN Setup"?
Question to picture above: Should I set all other ports to "Normal" or to "Fobidden"?
Any special treatment for port 28 (shared connection)?
Question to picture above: Should I set all other ports to "Normal" or to "Fixed"?
On what configuration page can I set the PVID and assign it to port 24?
All other ports to "Normal"?
Where can I set the "PVID 2" and assign it?
I hope after you answered the open questions I will be able to make this setup work without any more questions.
Thank you again for your help!
Florian
Hi @fquadt,
1. Switch 1 port 28 also need to fix VLAN 2. The other ports can be "Normal" or "Forbidden".
The difference is that "Normal" means this port can dynamically join this VLAN by using GVRP.
"Forbidden" is to prohibit this port to join this VLAN.
And VLAN 1 you don't need to change other ports' settings.
2. Please go to Advanced Application > VLAN > VLAN configuration > VLAN port setup to configure.
3. Same as answer 1.
4. Same as answer 2.Zyxel Melen0 -
Hi Melen,
thank you again for your answer. So I will summarize in the following table, what I have understood:
TaggingVLAN2 Control & Tagging PVID Switch 1 - Port 24 (Router2) Forbidden
untaggedFixed
untaggedPVID 2 Switch 1 - Port 28 (Connection to Switch2) Normal
taggedFixed
taggedForbidden
taggedPVID 1 Switch 2 - Port 19, 20 (VLAN2 devices) Forbidden
untaggedFixed
untaggedPVID 2 Switch 2 - Port 52 (Connection to Switch1) Normal
taggedFixed
taggedForbidden
taggedPVID 1
Is this the correct setup? Could you please esp. check the settings for the ports 28+52, which connect both switches and have to transport frames of both VLANs? For this they must be allowed to be in VLAN1, aren't they? Normal or Fixed?
The ports connected to the VLAN2 devices (router, NAS, etc.) should get PVID 2. I have found the configuration page but there are a lot more settings such as- Ingress Check,
- GVRP,
- VLAN Trunking and
- Isolation.
Again, I am very grateful for your support!
Best regards
Florian0 -
Hi @fquadt,
VLAN1 on ports 28+52 should be fixed so the VLAN 1 frame can be transferred between switch 1 & 2.
And you don't need to enable ingress check, GVRP, VLAN trunking, and isolation. You just need to change the PVID here.
Zyxel Melen0 -
Hi @Zyxel_Melen,
untaggedFixed
untaggedFixed
untaggedNormal
untaggedFixed
untaggedFixed
untaggedNormal
taggedPVID 1
Best regards
Florian0 -
Hi @Zyxel_Melen,
last weekend I tried the suggested setup. Configuring switch 1 went well but during the configuration of switch 2 I was suddenly locked out (no access to switch 2 enymore) and had to restart the switch(es) to reload the previous settings.
untaggedFixed
untaggedFixed
untaggedNormal
untaggedFixed
untaggedFixed
untaggedNormal
taggedPVID 1
Best regards
Florian0
- 439 Beta Program
- 529 USG FLEX H Series
- 330 Security Ideas
- 291 Service & License
- 4.6K FAQ
