How do I configure the ZyWALL for a L2TP server behind NAT?
Zyxel_Charlie
Topology:
Network Conditions:
Router WAN IP: 59.124.163.151
ZyWALL WAN IP: 192.168.10.33
Configuration on the router:
Add a NAT rule for the router.
Allow L2TP services.
L2TP server: 192.168.10.33
L2TP service: IKE, NATT, L2TP-UDP
Configuration on the ZyWALL/USG:
IPSec VPN Gateway
IPSec VPN Connection:
The local policy is the NAT public IP address.
L2TP VPN:
Assign a pool for the L2TP clients.
Create a registry key on Windows Client:
(1) Start > cmd > Enter "regedit"
(2) Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent
(3) Add a RWORD(32 bit), and name is: AssumeUDPEncapsulationContextOnSendRule
(4) Edit value as 2
(5) Reboot PC.
(5) Reboot PC.
On Windows 10, edit in the registry and then reboot.
REG ADD HKLM\SYSTEM\CurrentControlSet\Services\PolicyAgent /v AssumeUDPEncapsulationContextOnSendRule /t REG_DWORD /d 0x2 /f
VERIFICATION:
Use a smartphone or a PC to establish a L2TP VPN connection the to ZyWALL/USG.
Configure the NAT's public IP address as the L2TP server address on the client.
Hi @PaoloFracas
You can have a try to use IP 0.0.0.0 address object as "local policy" in phase2 setting.
There is a way to use a FQDN instead of the Static IP as "Router WAN IP"?0
You use interface IP which links to what WAN IP you have for that interface
Hi @PaoloFracas
I have checked the solution and it works.Thank you.0
THANKS! This manual helped me to find missed required setting :)
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
