How to get bandwidth usage logs
Hi @Milos
Currently device not support sending traffic log including Username/Network bandwidth/ Destination Web Site/ Timestamp.5
Hi @Milos
Current USG is able list how many times that user accessing to WebSite.
But your requirement needs analyzed by additional server. You may consider SecuReporter.
It can list all of users accessing history and timestamp to the website.
And it is able list how many bandwidth is used.
Thanks! If I understand correctly, secu reporter is not yet live, only available to a limited group of testers in beta. On our end, we're building our own secu reporter if I may say so, and need to know what logs is ZyXEL USG able to send. We are interested in bandwidth usage logs per IP and traffic type.
Any news on this?
Hi @Milos
Currently device not support sending traffic log including Username/Network bandwidth/ Destination Web Site/ Timestamp.5 -
Thanks to ZyXEL that they started do carry about their custommers needs. I have checked the SecuReporter but I miss one elementary report - overall bandwidth usage (current and historical per WAN/LAN port in KB/s or Kb/s or Mb/s..whatever but not only a pps like now, THANKS!
@IntL_Daniel, how did you started using the SecuManager?
Hi @Milos,
To use SecuReporter, you need to upgrade the device to firmware 4.32.
Go to myZyxel.com to activate the SecuReporter trial service.
On ZyWALL, go to CONFIGURATION > Cloud CNM > SecuReporter.
Enable “Enable SecuReporter” and “Include Traffic Log”.
Go to MONITOR > UTM Statistics. Make sure “Collect Statistics” of each UTM service is enabled.
On SecuRepoter, go to Settings > Add Organization and add ZyWALL to the organization.
Login to SecuReporter with your myZyxel.com account.
https://secureporter.cloudcnm.zyxel.com/
Is it available for USG310?It has 4.31 firmware ?0
Hi @sk8erbender,For USG310, SecuReporter will be available on the device ZLD 4.33 firmware in January of 2019.0
We use PRTG Network monitor with our Zyxel Routers. https://www.paessler.com/bandwidth_monitoring The Free version will allow you to see bandwidth usage. It's all done via SNMP.I wish Zyxel SecurReporter would have similar functionality, but it doesn't.Here's an example. Inbound and outbound traffic are shown as above and below the centerline.
- 588 USG FLEX H Series
- 476 News and Release
