USG 1100 policy route don't work, the packet outgoing interface: doll
alexey
alexey Posts: 188  Master Member
Hello.
Site A - usg 1100 v4.72
Site B - usg flex 50W v5.32
Build 2 vti interfaces in trunk. Added policy route to Sote B via trunk.
Device from site A don't have access to site B.
In routing traces i see, that traffic goes to doll interface
172.20.0.90:0->172.20.77.61:0
49316
ICMP
local
The packet outgoing interface: x
49316
ICMP
local
The packet outgoing interface: doll
Site C - usg flex 50W v5.32
Site A connected to Site C with same config. All work perfect, in routing traces traffic goes via vti interface.
172.20.0.90:0->172.20.58.5:0
35303
ICMP
local
The packet outgoing interface: vti16
35303
ICMP
local
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,338  Zyxel Employee
    Hi @alexey
    Could you share your network topology with IP address for us? It is convenient for us to realize your situation. Thanks.
  • Zyxel_Jeff
    Hi @alexey
    Please share your policy route setting with us as well. We would like to check the next hop setting. If you could share both devices' configs with us by private that would be better. Thanks.
  • Zyxel_Jeff
    Hi @alexey
    Additionally, if the next-hop is chosen as a tunnel and the outgoing interface is the doll interface while you execute the trace route action. Let you know that. Thanks.
  • alexey
    Hi @alexey
    Main office with 40 sites connected by ipsec/vti/vti in trunk.
    Firstly, problem site was connected via ipsec tunnel with dynamic peer. All work fine.
    After configure 2 vti interfaces in trunk, policy route was change to new next hop via new trunk.
    Site began unavailable on both sides.
    Traffic goes to doll interface.
    After reboot USG1100 with no changes in confuration file all start work as expected. Mysticly!
    So i see this reproducing steps:
    1 USG Flex 50 connect via USB modem by ipsec with dynamic peer for long time with connect/disconnect.
    2 Disable ipsec tunnel, create 2 vti interfaces beetween devices and union they in trunk.
    3 Change policy route to new trunk.
    4 Nothing work
  • Zyxel_Jeff
    alexey said:
    Hi @alexey
    4 Nothing work
    Hi @alexey
    Thanks for your response, we would like to clarify your reproducing steps:
    "So i see this reproducing steps:
    4 Nothing work"
    So, the 5th step is to reboot USG1100 and USG Flex 50 and then the policy routes(the next hop with VTI trunk) are working suddenly?
    Thanks.
