Maximum sessions per host
Hi @GianniA
Welcome to Zyxel community. The message "Session Limit Maximum sessions per host (1000) exceeded" is to remind your host already reached the maximum session limit value of 1000. Please check the host whether is executing unnormal behavior or not. Once you confirm it's normal behavior, you can set the session limit to unlimited or enlarge the session limit value then won't appear this warning message on the Monitor log. Please refer to the below example. Thanks
Hello all, I receive loads of log messages that say that Maximum sessions per host (1000) was exceeded on a ATP200 device. any solution?
mybkexperience
Greptol
May I know what firmware version you are using? Could you confirm whether the host executes multiple session behavior such as Bitcomet P2P transfer, file transport, etc? Thanks.0 -
It looks like your server has reached the maximum session limit value of 1000. have you successfully fixed it?
- 588 USG FLEX H Series
- 477 News and Release
