xgs2210 I lost ip interface
CCVO
CCVO Posts: 8  Freshman Member
Hello
I have 2 xgs2210 switches in a stack.
I don't know why but I lost the web interface.
I connected to the console to assign it a new management address but I have errors (routing table)
do you have a procedure?
Best regards
  • Zyxel_Chris
    Zyxel_Chris Posts: 729  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    @CCVO,
    Could you please use Zyxel ZON utility to set IP address, if still not works then please screenshot the error message with your configuration file private message to me.
  • CCVO
    Hello, ZON finds the switch. but does not react.
  • mMontana
    mMontana Posts: 1,428  Guru Member
    Can you restart the switch via the little clip-operated button?
  • CCVO
    I restarted the switch, I also injected an old configuration. the state does not change
  • Zyxel_Chris
    @CCVO,
    Thanks for your update, could you screenshot the console error message also with the running configuration, please private message me, thanks.   :)
