Flex 700 - Certificate download has failed
I have a USG Flex 700 running firmware version 5.31(ABWD0) which is having the same continuous error "2022-09-26 14:45:03 error myZyXEL.com Certificate download has failed.).
I have tried unsuccessfully to perform the update manually, but it continues to fail that way as well. "SSL Certificate download has failed. (failed) at Mon Sep 26 15:18:05 2022"
How can I correct this issue?
Jay
Hello @jayd691,about "SSL Certificate download has failed", is it a log or a pop-out error message? could you provide a screenshot of it?Moreover, could you provide remote access to me via private message? I could help to check on this, thank you.James0
Hi James,
It is logged when the update is automatic, and it is a pop-up window and logged when I try to update it manually, which I found in the community resolved this issue previously.
Jay1 -
Hi all
Same issue again as previously.
Printscreen here:
It works now on my side.
BR Daniel0 -
And how do you manage it in Nebula?0
- 7.8K All Categories
- 1.6K Nebula
- 55 Nebula Ideas
- 53 Nebula Status and Incidents
- 4.3K Security
- 217 Security Ideas
- 908 Switch
- 40 Switch Ideas
- 807 WirelessLAN
- 16 WLAN Ideas
- 5K Consumer Product
- 131 Service & License
- 260 News and Release
- 49 Security Advisories
- 6 Education Center
- 573 FAQ
- 273 Nebula FAQ
- 132 Security FAQ
- 73 Switch FAQ
- 72 WirelessLAN FAQ
- 7 Consumer Product FAQ
- Documents
- 67 About Community
- 40 Security Highlight
