ATP let VoIP Pass truth?
Username_is_reserved
in Security
Hi
Maybe someone have a good idea why the VoIP from my ISP get blocked?!
Security Policy Control Match default rule, DROP [count=5] XXX.XXX.XXX.XXX:5060 YYY.YYY.YYY.YYY:40259 ACCESS BLOCK
x= IP from my ISP for VoIP (how it seem like)
y= My Fix Wan IP via a PPoE "Dialup" to my ISP
5060 is the "default" Port for VoIP.
So what is be curiose that "Y" show my fix Wan IP.
No one wrote a security policy to allow it.1 -
Is SIP ALG enabled on ATP?
Thanks for replay everyone. I try but what is the "magic phrase" to add?
I set Wan -> Lan1, Port 5060 (out of my brain) that should do the job?!
It's not "magic", it's simply a correct written rule. NAT and security policy/firewall.Consider everything as device perspective, not whole.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
