Delete USG20W-VPN unused SSID
mMontana
mMontana Posts: 1,468 image  Guru Member
edited October 2022 in Security
Device installed during 2019 with 4.x firmware. Works nicely. Has 4 SSIDs configured.
Item #1 maybe is born with the device. Was not interested, left it there.
Item #2 and #3 were created by me on ZLD 4 firmware.
Item #4 maybe arrived with later update.
Button Add works, but tells me "too many SSIDs". Fine.
No delete button. No delete option into SSID details.
Am I missing something?
  • Zyxel_Cooldia
    edited November 2022
    Hi @mMontana,
    Thanks for issue report. Maximum SSID profile should be 4.
    The "Add" button doesn't make sense. We will discuss internally, and update status on this thread
  • mMontana
    edited October 2022
    Is necessary to discuss simply adding a called "remove" or "delete"?
    I mean: already senseless to forcely have 8 different profiles into APs (which can be disabled but not deleted).
  • Zyxel_Cooldia
    Hi @mMontana,
    Per checked, 4 SSID profiles is mainly for quick setup wizard. that's why there is no delete on that page.
  • mMontana
    IMO, if there's an "add" a "delete/remove" is needed.
  • mMontana
    Up. Any updates?
  • Zyxel_Cooldia
    Thanks for feedback.
    Considering its related to quick setup wizard, and there is no major issue in the current design,  we are more prone to stay at the current design.
