monitoring usg 60
Georgii
Georgii Posts: 16 image  Freshman Member
Good day!
We use USG 60, we want to put the network interfaces of the device on monitoring. We tried through Zabbix, but we did not find the required template.
Tell me a template or how can I monitor device interfaces from a local network?
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    Zyxel MIBS files are something to start with.
    Or you can write your own module for Zabbix...
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Georgii
    Do you want to import MIB file? If so, you can refer to this link to see how to import it.
    Besides, you can refer to this link to download USG60's MIB file. Thanks.
  • Zyxel_Jeff
    Hi @Georgii
    Additionally, you can refer to our cloud-based security monitor solution SecuReporter. Thanks.
