IPSec VPN. How to create connection with multiple local and remote networks
bk1
bk1 Posts: 5
Hello.
I Try configure IPSec with remote office. In connection settings I can add only 1 local and 1 remote network.
What should I do, if I have 3 networks:
10.80.6.0/24
10.80.10.0/24
10.80.12.0/24
Remote office has more networks:
10.88.12.0/24
10.76.0.0/16
10.10...
and etc.
  • bk1
    bk1 Posts: 5
    edited November 2022
    @mMontana
    Yes, It is work, but it is really uncomfortable. I should to create 31+ VPN Connections.
    Maybe there is another option?
  • mMontana
    mMontana Posts: 1,432  Guru Member
    Command line interface.
    If this arrangement sucks for you, sucks for me too, but it's the way that Zyxel request for making it work.
    I know there's a limit of tunnels (gateways) dependent from the device model, i don't know if there's a limit for subnets/connection/tunnel on the same gateway.
  • bk1
    bk1 Posts: 5
    @mMontana
    Thank you very much for answer
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @bk1.
    You also can add policy route for site to site VPN multiple subnet routing.
  • Zyxel_Cooldia
    Hi @mMontana,
    Thanks for the example. ;)
    In site 1, add policy route for subnet 172.31.128.0/24 routing.
    src = 192.168.199.0/24
    dst= 172.31.128.0/24
    next hop = Site to Site VPN tunnel
    In site 2, add policy route for subnet 192.168.199.0/24 routing.
    src = 172.31.128.0/24
    dst= 192.168.199.0/24
